Hi everyone, I was wondering if it was planned to have multiple different parameters per control including different midi channel ?
I’ll explain myself a bit, I’m using a novation summit and until now I was using a morningstar mc6 to call patches on the summit.
Since the mc6 does not allow NRPN directly, I used a serie of sequencial commands to call a specific patch.
Summit has 2 modes : Single and Multi(timbral) are reachable from NRPN 62:0 which has to be sent on global channel for single to multi ( 7 in my case ) and on any part channel for multi to single ( 5 or 6 for me ).
Each mode has its own four banks
Each bank has 128 patches.
The mc6 allowed me to have two set of instruction per stomp (Switch position A and B ) to switch from single to multi.
Basically it is needed to send :
cc#99=62 then cc#98=0 ( Paremeter id ) then cc#6=1 ( Value ) then cc32=1-4 ( bank ) then pchange = 0-127 on channel 7 to call a specific multi patch.
And exactly the same as above except cc#6=0 and channel 5 or 6 to call a monotimbral patch.
Is something like that could be attainble with the electra one on one button ?
I already set up a single to multi switch using NRPN list but it needs two buttons ( one for each midi channel) with 2 options each, one to send the correct command and another to reset the command so you are able to send it again. Not very convenient at the moment.
Thanks a lot for your help, I hope my post made sense…
