I always wondered, can Roland System-8 handle sysex? The short answer is yes.
I started by sending a patch from the Roland System-8 VST editor to the System-8 hardware and at the same time I recorded all the messages with a MIDI Monitor. When you look in the MIDI Monitor, you see that there is a lot of handshake from the beginning. It stops after a while. There are a total of 111 (small) sysex messages to be sent for a patch. Once I had saved all the messages to be sent, I sent these messages back with SysEx Librarian. It works! The patch is sent to the System-8. I tried several times to change the patch on the hardware and then I sent. The patch name changes in the display. SUCCESS!
So what can be concluded from this? Yes System-8 can handle sysex but Roland won’t tell you how to do it. Roland should be ashamed. System-8 can do the same if you send a whole bank of 64 patches. The difference is that when the transfer is complete, System-8 starts a write process. If you just send one patch like I did now, it ends up in the edit buffer and disappears when you turn off the power. Much like most synths work.
I don’t know what all the sysex messages mean yet. Reverse engineering and plenty of time is required for that but… It’s nice to know that System-8 can actually handle sysex. Now you can save all your patches in a library and send them to System-8 when you need them and forget the SD card.
