setMin and setMax no longer working as before
I made presets before such as the one for the Korg 03R/W where the display limits of a control are set dynamically using value:setMin and value:setMax functions. But in FW3 they do not behave as before.
Before FW3 they indeed worked as new display values, using the full range of the bar to go from the new setMin value to the setMax value.
In FW3, it looks like the display limits are retained/imposed as set in the MIDI min and MIDI max of the control itself.Any value in setMin or setMax outside of the MIDI values is no longer reachable. Any value set that is within the MIDI values just limits the travel of a control.
To reproduce, load preset Electra One App
In its fx page, choose ‘reverb hall’ as FX1 TYPE. This will limit the travel of reverb time (the third control on the screen) to move from 0 to 99. That used to use the full length of the bar, but as the control MIDI values go from 0 to 200, it now uses only half the bar.
The ‘eq low’ and ‘eq high’ controls on the second row are worse, as their setMin = -12 and setMax = +12. But their travel is now limited to 0 - 12 , only using the first 6% of the travel between 0 and 200.
Martin and i had a brief exchange about this
Thing is: it used to work differently, so some of the former presets aren’t working anymore as supposed.
It used to work as follows: with the MIDI min / max you set the boundaries of the values transmitted, whereas with the display min/max you set how the values are displayed. The latter used the full scale of a control, and that is no longer the case.
I do think it’s a bug, as it diminishes functionality.
agreed - when I first ran across that, I ended up doing a redesign to use a different way.
Also, since we’re keeping track -
if you use
myBounds = control:getBounds()
and then pass that to a helper to convert to a slot:
mySlot = helpers.boundsToSlot(myBounds)
print("Slot = " .. mySlot)
you always get 1
I wrote a quick converter function to use for now:
function cvtToSlot(bnds)
   local myX = math.floor(bnds[X] / 167) + 1
   local myY = math.floor(bnds[Y] / 90)
   return ((myY * 6) + myX)
Not sure how many people are making decisions based on where the control is located, but I found that to be useful for my PCM 70 preset.
Replicated and understood. It is a bug indeed. In FW3, only the preset “data model” gets updated but the visual component is not rebuilt. If you switch to different page and then come back to the FX page, it will work properly. I am already fixing it.
@NewIgnis @oldgearguy can you test 3.1.5 on beta. This should be resolved.
@oldgearguy - the boundsToSlot function (you mentioned above) is fixed too.
I should have some time later today. Thank you for addressing so many areas.
It’s still doesn’t work? I’m trying with that for few last hours, and it’s make me incredible sick. Values always are set to 0-127, but every parameter what i want to set has dynamic changes of increasment due to mode of working. It’s working like in topic always, and i’m not content from that. I was trying with setlabel() too, to cheat framework, but can’t get it.
Anyone, anything ? I’m trying with that more now, I know difference between MIDI min and MIDI max, and Value Min/Max, it would be simply if i can set it manually on Layout, but i need to implement dynamic changes from Lua code. I can set dynamic Midi send and phisically lock border for encoder like You see on video. But i can’t set it to use all range of encoder, only for few steps, like Value Min/Max do.
can you share (here or PM) a link to that preset. It would be the easiest way for me to review it. thanks!
Yesterday i didn’t get it again, and deleted my attempts, and i don’t have it right now. I make other things in that preset on clean version. I will back to it, i repaired glitting on the screen, and have little synchronization problem, i’m looking right now, to make it right, and will back to it soon. Maybe tonight will make it in time, and will back to it for sure. I have one more idea for that. Thanks for anwser.
Oh gosh, it was hard to set it propertly. I spend last 2 months with totally other and bigger problems, and needed to try with it again later. I was approaching it like 4 or 5 times more, and never get answer to it, to this day. I was trying to paint custom control, and then realize control ID it’s not this same like parameter ID. But i was looking for control ID and can’t find it, then i realize control ID is defined in Json as a “reference”… AI dont get it, and never give me an propertly anwser, and hard to realize it in documentation. So i did it try again and finally it works !
