Not sure whether this is a bug or just me in my first day with the E1…
I have a keyboard controller (SL Grand) connected to the USB Host. If I press keys, some notes will be eventually lost. No need to play virtuoso, I can reproduce the problem just by pressing a key every second for half a minute or less.
- It happens on Linux and Windows with the same frequency, so I don’t think it’s my PC.
- It happens only when I connect the controller to the E1 via USB, if I connect the controller to the PC directly it’s all fine, therefore it’s not the controller’s fault either.
- It happens with two different apps (Bitwig and Numa Player) and therefore the app isn’t to blame either.
- Connecting the controller to the E1 port 1 via MIDI DIN cable works just fine. No notes lost, which seems to isolate the problem to the USB Host.
I haven’t touched the initial E1 configuration. (Should I? For now I only plan to connect this controller to the E1 and all I want is a MIDI Thru going to the PC.)
