Here is a first cut at a preset for the tc D-Two delay unit: D-Two
Some notes – it’s not done, but it’s useful and fun.
For now (until I have time for more thought/edits), the preset starts with the following assumptions:
- sysex ID = 0
- MIDI Channel Channel = 1
- MIDI CC = On
- MIDI Program Bank = External
If you do not have CC and Bank set properly inside the D-Two, the preset will jump to the configuration page and let you know what to fix the first time you try to pull down a preset.
You can change the sysex ID, but it you do the next time you start things up, there may be confusion
- Add preset rename/save – WORKING
- Change max times when going between mono and stereo – BETTER
- Create some additional control lockouts (no repeats, PingPong not available, etc) – BETTER
TODO:
- Deal with the Rhythm mode fully. You can currently edit Rhythm presets, but creating them from scratch is not really working
Any/all feedback is welcome of course.
EDIT - preset renaming and saving to the User area is now working. Still need to fill out User name list with saved patches. Still things to clean up, but at least now changes can be saved.
