u-He Repro-5 Enhanced Preset
Hi All,
This is based on my Repro-1 mod of Christian’s preset!
Repro-5 Preset
com.u-he.Repro-5.midiassign.txt (8.5 KB)
Functionality:
  • 14 bit resolution for VCF cut-off frequency parameter. You can now more accurately tune the VCF when used as an additional Osc
  • Dedicated Envelopes page allowing access to all VCF/VCA parameters and tweaks. Designed to avoid button hopping when fine tuning!
  • Dedicated ‘Perform’ page allowing access to all mod-matrix functions. Note: mouse still has to be used to select destination as this is not midi enabled in Repro-5
  • Dedicated ‘Voice Pan’ page
  • All midi controllable parameters configured with exception of ‘Width’ control in Sonic Conditioner, ‘Amount’ and ‘Tone’ when Distortion is set to Corrode & Master Tune. Just ran out of CC’s unfortunately and had to make some tough choices. You can always reallocate from something you don’t use if these are important to you!
  • Effects enablement, order and selection of Velvet effect ‘Type’ must (sadly) be done with your mouse as unfortunately this is not midi enabled in Repro-5
Do let me know if you find any issues.
Hope you enjoy and happy patching.
Diva next then Hive 2 although these are going to take a lot of thinking about!
Si
Hi - just wanted to say thanks for creating this comprehensive preset (& to @christianvogel for the OG preset). I just purchased Repro-5 in the Black Friday sale, so I intend to use this E-1 preset as I learn the synth.
Glad you’re digging it!
Just one thing to be aware of that I spotted the other day - the select midi channel functionality isn’t working at the mo. Taking a look and will update.
Su
Glad you like it, enjoy :slight_smile:
