I created a preset for the software U-HE Repro-1 synth.
You can set the midi port and channel in the config+tweaks screen. Also, double-tap a pot to toggle a button or reset a pot.
https://app.electra.one/preset/4SLfpELK8caLvdEBVzMc
You will need to MIDI-learn each control in Repro-1, I have not found a way to export the MIDI-table. Also, at least in Bitwig I have not found a way to (without a Bitwig plugin) get the VST output. Maybe in the future I will try to write a Bitwig extension for this.
The sequencer has not yet been assigned and is unfinished, still working on that part.
