Hi all. I’m connecting my Oxi One to the Electra mk1 host port. It only registers the Oxi maybe 1 time in 4 (requiring multiple restarts, never when just connecting while everything is on), then sometimes loses connection seemingly at random. I’m using the original Oxi USB cable and the Electra is plugged into a decent USB wall plug (10A I think)
Hi. I have a Mk2, running latest 3.7f beta firmware, and it seems to work for me, also using the original Oxi One USB cable. I sometimes need to reset / reboot the E1 after plugging in the device to get it to send out MIDI. But seems solid after that … I have just been playing with the Oxi’s MIDI CC to CV conversion feature (converting a MIDI cc1/channel1 fader on the E1 to a CV signal patched though the Oxi Pipe into my eurorack case). Remember to set Oxi One as a “USB Device” in the Oxi’s system settings. I don’t know if any of that helps, good luck in getting it working…
I just tested mk1 with v3.5.4 with Oxi One connected to the USB host port. It is recognized and E1 receives the data just fine. Then I tried to switch Oxi One on and off while being connected. That worked fine too. The same counts for disconnecting the USB cable while Oxi One was on and running a sequence.
Have you tried what @Phommed suggested?
