If I use the electra’s host port to receive Sysex messages from a Teensy 4.1 based synth, longer messages are corrupted after about 50 bytes. If I switch to using the DIN ports, it all works fine. Is it possible the synth sysex output is too fast for the electra to keep up, or is there something I might be able to change in the electra to improve this? Would the latency be any better on the USB ‘Device’ port (I can’t test this and run the lua editor at the same time at the moment)?
p.s. Sending the same messages from the synth to my (old) computer running MIDI OX works just fine too btw, so it would be a bit disappointing if I can’t get the electra’s USB host port to work.
