Hi, I might be tempted to start building presets for software VST (espeicially those from Waldorf , Arturia , Cherry Audio, Full Bucket, GForce, Korg, Usual Suspects) on the Electra One, operating similar to those I make for hardware synths, so including preset browsing, name setting and parameter parsing & control. I use Ableton 12 as a DAW.
I’m being suggested that the key to make this happen in a generic way is by involving Max 4 Live in the process, so it can be used to create sysEx like data for the Electra one to understand. Perhaps I can make some king of wrapper with Max 4 Live so the VST -specific work on the Electra can be limited to all the info I cannot get out of a VST (such as the option lists, the preset bank structure, the slots for the parameters to be shown)
Well it’s out of my comfort zone. If I would work with a remote script, how does such concept work? (Never needed to use any scripting for hardware synths). But max 4 live is equally unknown to me. I just need to be guided in a good direction.
Also relevant is I want to control the VST regardless whether they are in focus on the DAW or not. So any VST being used in the DAW should be enabled to be controlled via the E1, as long as it has been assigned to a DAW track, but without it being visible on the PC screen.
Is that possible without Max4 Live ?
I’ll probably need your help. The plan for me now is about studying and learning first:
take the assumption Max 4 Live is not needed for this goals
understand the concepts you’ve already made with Ableton
get your Ableton mixer up and running
understand the Github concepts (so far I’ve always maneuvred around it, but it’s time now to take the dive, I guess)
understand how Ableton deals with control surfaces and scripts
only then see how all this new knowledge can be used for the end goal i.e. have VST’s behave via the E1 as if they are like any other hardware synth in the studio that is too far to control on the device itselve and thus require the E1 to control them.
Only caveat for Ableton is that vst and vst3 plugins are limited to 128 parameters. If you want more you need to wrap the VST in a M4l wrapper (quite a few out there already)
Iirc there’s a video of using the script on Electra on yt
