Misi
November 7, 2021, 11:18am
1
Hi there,
Electro midi 2 IO is connected to an Access Virus ti2.
DAW is not running.
I have the following parameters mapped to control the virus:
part select
volume
I apply changes to the default volume settings.
Press save snap on electra.
I apply more changes.
Load snap from electra.
The following happens when I load any snaps.
The virus jumps to the 6th part on the Virus.
Changes all the volume to -64.
Switches off global config keyboard setting, local keyboard on the instrument is off.
Any suggestions why is it happening?
Thank you!
Are you using the editor from @joris.rolling ?
in the description there is written:
IMPORTANT : This Preset assumes you have set your Access Virus TI to MIDI Device ID to Omni.
have you set that?
just a wild guess. cheers Tim
Misi
November 7, 2021, 6:20pm
3
I tried with omni and set to an exact number which is 1 in my case. Same results
Misi
November 7, 2021, 6:21pm
4
No, it is my own thing. But I tried his Access template and I have it saved on a different preset bank.
martin
November 9, 2021, 11:56am
5
Hi @Misi , please share the link of your preset. I do not have TI2 around but I can take a look at what messages are sent when twisting the knobs and on loading the snapshot. I assume there will be some discrepancy in that.
Misi
November 9, 2021, 12:52pm
6
Hi Martin,
I made it public, here is the link:
https://app.electra.one/preset/IkG3zsHiPtaZnTVqMXoB
Thank you!
