Back to default parameter value via double tap
It would also be good if we can set the time in milliseconds for the double tap in global but personally it would be much more nice if we can do this PER knob.
See details here: Electra One: back to default parameter value via double tap - YouTube
If technically possible also via hold tap on top of a knob.
…and ideally you can edit the milliseconds per knob.
Also interested by this idea here. And why not be able to toggle between minimum and maximum ?
