Double tap pot for default value
Double tapping a control on screen resets it to the default value. Would it be possible to recognise a doble tap on a pot to also reset a control to its default state? Or would that be ‘dangerous’ as it means that occasionally when you control a parameter with a pot you accidentally hit it twice and then the value jumps to the default?
I enabled that in the past and it was too sensitive indeed. I was having the value reset to the default too frequently, without doing the double tap.
Shame, but then the current situation is more robust and safe.
