It would be a huge help if we could double tap an encoder to reset the value to the preconfigured ‘default value’. If that solution is not advisable because of ‘tap-errors’ it would be great if one of the buttons could become a shift button. That way, shift plus encoder tap could reset the value.
Edit:
Or another solution (maybe even better): double tap on the touch screen to reset
Thank you!
