Dear electra one mk2 owners(and ofc mk1),
I am quite new to midi mapping and I have quite some difficulties trying to map these two devices.
Basically I want to create a layout where I can send different program changes mapped under the same button aswell as for the Tanzmaus.(for the tanzmaus this is pattern + one of the steps) and the Op-Z(this is P + number + trackchannel).
I want to have a trackmute function screen for the Tanzmaus
A trackmute function screen for the Op-Z(accessed via the mixer button on top and then selecting each track respectively for on/off)
A tape machine push section for the Op-Z(track 12)
A push in fx section for the Op-Z(track 14)
visual encoders & knobs for the Op-Z visuals(track16)
light encoders & knobs for the Op-Z lightning track(track15)
For the tanzmaus the manual doesn;t make any sense as how to program this, could anybody shine some light on this?
page 35 is the midi information. I can see this in the manual:
MIDI Implementation
MIDI Controller assignment
MIDI_CC_BD_ATT 2
MIDI_CC_BD_DECAY 64
MIDI_CC_BD_PITCH 65
MIDI_CC_BD_TUNE 3
MIDI_CC_BD_NOISE 4
MIDI_CC_BD_NOISE_DEC 5
MIDI_CC_BD_DIST 6
MIDI_CC_BD_TRIGGER 66
MIDI_CC_SD_TUNE 11
MIDI_CC_SD_NOISE 13
MIDI_CC_SD_NOISE_DEC 67
MIDI_CC_SD_TRIGGER 70
MIDI_CC_SD_DECAY_TONE 71
MIDI_CC_CP_DECAY 75
MIDI_CC_CP_FILTER 18
MIDI_CC_CP_ATTACK 76
MIDI_CC_CP_TRIGGER 77
MIDI_CC_TT_TUNE 19
MIDI_CC_TT_DECAY 20
MIDI_CC_TT_TRIGGER 78
MIDI_CC_TT_ATTACK 79
MIDI_CC_TT_PITCH 82
MIDI_CC_TT_PAN 73
MIDI_CC_SAMPLE1_TUNE 84
MIDI_CC_SAMPLE1_DECAY 85
MIDI_CC_SAMPLE1_SAMPLE_SELECT1 86
MIDI_CC_SAMPLE1_SAMPLE_SELECT2 87
MIDI_CC_SAMPLE1_ATTACK 88
MIDI_CC_SAMPLE2_TUNE 89
MIDI_CC_SAMPLE2_DECAY 90
MIDI_CC_SAMPLE2_SAMPLE_SELECT1 91
MIDI_CC_SAMPLE2_SAMPLE_SELECT2 92
MIDI_CC_SAMPLE2_ATTACK 93
The MIDI channel for controller data transfer is
always the same as the channel of the corresponding instrument. It is selected with the MIDI
Learn function.
Tanzmaus responds to the following MIDI data:
MIDI_CLOCK
MIDI_START
MIDI_CONTINUE
MIDI_STOP
MIDI_NOTE_OFF
MIDI_NOTE_ON
MIDI_CONTROLLER
MIDI_PROG_CHANGE: 0…63
MIDI_SYSEX
MIDI_SONG_POSITION_POINTER
( https://media.djmania.net/manuales/pdf/Manual_MFB_Tanzmaus.pdf )
but which midi channel is this?
And with the Op-Z I can find this in the manual:
https://teenage.engineering/guides/op-z/midi
I am just totally confused and am afraid that I have to program stuff in to Lua, but my liveshow is in 15 juni, and I am so scared it is not going to work out ![]()
I hope somebody can put me in the right direction.
PS: So far it seems that when you put the Tanzmaus in manual mode instead of step mode it will react to incoming midi but when I put the tanzmaus in manual mode all preprogrammed knobs of the decay et all of the different analog drums will go to the value they are at in realtime on the machine, which isn;'t exactly what I want.) the only thing I really would want to control of the tanzmaus is the mute section of the tracks and the program changes.
Thanks so much
