Current working version: PCM 70 beta
If anyone has time (and are running the 3.1.7 beta), I’d like you to take a look at the PCM 70 preset so far.
Mainly, I’d like some feedback on the control layout, colorization, and naming. I tried to keep it fairly uncluttered and consistent, but maybe people other than me should judge the success or failure of that.
The preset assumes by default you are using the first set of MIDI In/Outs of the Electra One and using MIDI channel 1 on the PCM 70. There is a temporary button on the first page to take you to a config screen where you can change those things.
Some notes working with the PCM 70 for a bit –
I can pull down Registers and Programs to be edited, but for now I do not have a way to save the edits to a new slot (I think I know how, just need to work it a bit).
If you want to edit a register, you can just turn the Patch Select control to a valid number and press the get patch button.
If you want to load and edit a Program, you need to press the front panel Program button so the LED is on, then turn the Patch Select control to a valid Program number (keep turning - you will see the name change from register to program).
There is no real nice way to get the names of stuff stored in the registers. I can (and will) hardcode the names of the programs for os 2 and 3 eventually, but for now you just see the xx.yy format.
I have been testing with OS 2 only so far. I burned EPROMs to upgrade to OS 3, but I’m waiting until I have everything correct for 2 first. Mainly because the parameters ranges and such do not exactly match what is documented (no surprise there).
The values displayed on the E1 generally match with what is seen on the PCM 70, with some minor rounding/exceptions. There is also the issue of changing the various delay times based on changes to the Size parameter. I do not have that working correctly yet.
For my use, I have my Electra One configured to use bars and unchecked both boxes in the UI section. Currently, I remember the last control you touched when you change pages (only applicable for the Echo/Chorus, Multi-band Delays, and Resonant Chords programs since they needed 2 pages).
MIDI patching is not there yet. I have an approach and have tested it before, but had to rip it out temporarily while redoing all the other pages.
So - progress made, but wanted some outside opinions on the UI.
If anyone wants to play with it without a PCM 70, download the sysex files posted earlier in this thread and use the MIDI console inside the web UI to send the sysex dump to the Electra One.
