If there are 16 steps for each channel, the Step-Select is CC55, is it possible that when a new step is selected, all the parameters for that step updates to it’s stored value? Flux’s midi controller manual says “When designing your controller, make sure to send a step select message before sending messages to a steps’ parameters. You only need to send a step select message once, then update all parameters that you wish to. Send a different step select message to begin addressing the parameters of another step.” How to implement this on Eletra One?
The second question is if Flux has 4 channels of outputs, midi channel 1 = Flux channel 1, 2=2, 3=3, 4=4. The parameters for all 4 channels are the same. Instead of copying parameters to a new page for a new midi channel, is there a better way?
I am pretty new to this, so any help would be much appreciated!
