This release brings mostly brings an update of the MIDI learn so that it can be used in combination with the new editor for Patch dump parsing (Patch Parsing tool - testing and help needed). There is also a minor fix oft the USB host device assignments.
Changelog :
Add support for visual patch dump editor
Fix USB Host device assignments in config.json. The 0 based index has been used while index starting with 1 is expected.
@martin FYI when I use the link above, I get to the new version. When I use the electra.one homepage, the main links in the upper right corner don’t function anymore. The links down below the homepage still work, but when I access documentation via those links, the ‘downloads’ page still shows 2.1.5:
