Graphics glitches after sending preset to mk2
Hi folks,
I’m noticing that after sending a preset from the web editor to mk2, I get graphics glitches appearing which gradually worsen over time. The only way I’ve found to correct it is a reboot - and it often takes a couple reboots to completely clear the glitches, after which everything works as expected - until I send another preset from the web editor.
Switching presets on the e1 doesn’t correct the glitches.
The glitches are most commonly fader names flickering above the fader while it’s in use, or in random locations on screen; a horizontal red bar flickers near the top of the screen; group labels flickering when knobs are turned; control labels disappearing from toggle pads (this is the last glitch that appears after time, and it affects the e1 menus).
Any thoughts on troubleshooting this? I see from other posts it could be corrupted data on the sd, but it seems odd that it only occurs after sending from the web editor.
Sounds like a “not enough power” issue to me
Thanks - I will follow that up.
