I’m using Keyboard Maestro to change preset on the Electra One but since Keyboard Maestro can only address his own MIDI port I also use Bome MIDI Translator Pro to re-route the Keyboard Maestro to the Electra USB port
If you’re referring to the Electra routing page the answer is no, because the problem is that AFAIK Keyboard Maestro is not capable of addressing other MIDI ports so it’s necessary to have something that’s capable of routing the Keyboard Maestro output to the Electra CTRL input
The translator I’m using is actually a blank one, I’m only using the MIDI router side of it to connect the Keyboard Maestro MIDI Out to the Electra CTRL In
