Turning a knob on the Electra One mkII to the left should decrease the knob’s value. However, turning any knob to the left will sometimes increase the value instead.
I noticed this for up to two values, but it’s often just one false increase. It seems that all knobs are affected by this and it also seems to happen when the knob has a specific physical rotation.
The problem is easiest to notice when twisting the knob with a slow movement. It is harder to notice with fast knob movements.
It has been happening in every preset I tried and it seems to happen for both LUA and JSON knobs.
It seems to be tied to a specific physical rotation/orientation of the knob.
I can even see the problem when the control is shown fully left/at zero in the UI. Slowly turning the knob to the left will make the value shown jump to the next increment at some point.
I’ve been having a random issue where I have a virtual control range of 0 to 299 and it takes a lot of movement to get it to start registering any changes. If I whip the encoder it get more response, but slow turns don’t register for the first 1/4 turn most of the time.
