Hi @martin,
You’re not watching ‘the game’ (Netherlands - Czech)?
0-1 now…
I am watching (enjoying) that indeed
Wow, 0-2 beautiful goal!
Congratulations @martin!
Yes, cz team is really good this year. Thx!
cool, thanks a lot for the modprobe hint on Linux!
a rather old post but that helped me immediately solve the problem that i could transfer a single patch after a fresh electra start, but all consequent attempts did result in failure and checking dmesg output i found these errors:
ALSA: seq_midi: MIDI output buffer overrun
so i knew somehow i would need to set the output buffer parameter, but not to which value… which I then found here ![]()
Adding the error message with this comment so people/search engines will find it…
What distro are you using? I have not seen that error yet.
It’s an Ubuntu 23.04 on an Lenovo ThinkCentre.
I haven’t seen that error before, with other controllers and synths, either. It took me a while until i thought of checking dmesg…
well, controllers do not usually transfer large sysex messages as E1 does. ALSA has a problem with processing large sysex on on time. Hence, it is easy to exhaust the buffer. That is the reason why the buffer needs to be increased. I usually set it so that even the largest presets can fit in it (currently around 350k).
What I meant is that I have not seen that message when the buffer is increased and you actually transfer the first preset. I will play around with ubuntu a bit…
I’m not sure if I understand this last sentence correctly.
It sounds like maybe you misunderstood me that I still have this issue after increasing the midi buffer.
But what I tried to say is that I got the error before increasing the buffer, and it went away after i increased the buffer… just to be sure ![]()
If you need any help in further investigations or trials, just let me know. I have a few more other Linux machines and Raspberry pies…
oh, I see
all good then.
Check the following thread - if you have not read it already - Ubuntu/Chrome connection problem - #10 by martin. There is a neat way to edit the/etc/modprobe.d to have it all done at the boot time.
Thanks - i had that already.
But with options I only set the options, one needs also a line in /etc/modules or in a file inside /etc/modprobe.d/*.conf that also does the module loading ![]()
