Hi, I’ve been having fun on the Mini making a patch for the Waldorf Protein. I was doing the whole preset build while triggering the Protein on the unit itself…Now today, as I was developing my patch, I wanted to connect my Keystep Pro to the USB host connector… I thought that the process was going to be as straightforward as plugging it in… nope.
Right away, the Mini recognize the KSP as a device, when I hit a key, it does register on the Mini screen but does not pass thru the info to the midi out (KSP flashes when operated).
The manual says that it should work without much explanation under “complex setup”. I tried several configs in the web “controller” section but to no avail.
Can someone please point me where these basics are explained? Would be appreciated
Thanks
