when I try to route messages from the device input 2 to din out 2 it works only if I don’t change preset, even using pin preset…
the label lights up showing messages are correctly received on the device port, I go to the router settings enabling the midi out 2 to output them and it does it lighting up the realated label, but when I move to a different preset stops running, to make it work again I have to go back to that preset and redo the job on the router settings….
would be also helpful to have a visual feedback on the router to understand how the messages are moving through the ports, simply the leds which light up when a message is received on that specific port
