Can you save your current Electra One Configuration you are changing that stores a current synth configuration you have set to a file on the box and then when you load that have it send all its current parameters to the synth maybe with a press of a control. Is there a function to resend all its current settings to the USB target?
Also I need to scale the midi values output next to each control based on the range you set in the configurator to be scaled to real number ranges (say to one decimal place). I assume that is something that needs to be programmed in lua. Would be nice to have an extra field in the editor to be the actual midi range set now (this applies more to 14 bits) which outputs the scaled float to the controls numeric tag.
Thanks
