I tried to utilize their MIDI learn feature, but it doesn’t save when you open the DAW again or allow you to export/import the MIDI. I had to map it in my DAW midi learn for it to stay.
MODEL 72.epr (10.1 KB)
I opened a support ticket to ask them to make it possible to export/import mapping.
They’ve added the feature to some of their synths recently.
Here is the cc config file matching the template from last October.
Softube Midi Settings.softubemidipreset.cfg (9.8 KB)
Remove “.cfg” from the end of the filename.
Quick note:
In Ableton, if interested in bidirectional control, the preset file is not needed. One needs to map the Ableton parameters shown in the rack.
